Deletes one or all member VLANs from a translation VLAN.
| vlan_name | Specifies the name of the translation VLAN from which you want to delete the member VLAN. |
| member_vlan_name | Specifies the member VLAN to be deleted from the translation VLAN. |
| all | Deletes all member VLANs from the specified translation VLAN. |
N/A.
This command removes the link between the translation VLAN and the specified member VLANs, but it does not remove the VLANs from the switch.
The following example deletes member VLAN leafvlan from the translation VLAN branchvlan:
configure branchvlan vlan-translation delete member-vlan leafvlan
This command is available on all platforms that support the VLAN Translation feature. For features and the platforms that support them, see the Switch Engine v33.1.1 Licensing Guide document.
